Ken Roach
Technical Management ?
The A-B controllers with which you are likely familiar (PLC-5 and SLC-500) use a register scheme in which each data type is represented by a letter, and all data addresses includes a data file number, a data element number and subelement number.
Got it ? File, Element, Subelement.
The first eight files in an A-B controller are predefined:
O0 Output
I1 Input
S2 Status
B3 Boolean
T4 Timers
C5 Counters
R6 Control Registers
N7 Integers
F8 Floating-Point
The syntax for most addressing is:
Type FileNumber : Element / Subelement
Thus a particular integer might be addressed as "N7:10" for Element 10 of File 7.
Subelements of predefined complex datatypes like Counters and Timers have mnemonic shortcut addresses you can use. The "Done" bit for Timer T4:5 is addressed "T4:5.DN", instead of actually specifying the offset bit inside the timer structure.
It's best not to boast about your skills while you are committing a major faux pas, kid. The above is for A-B controllers, as you stated, not for GE controllers, as you went on to ask about.
I use the A-B "Instruction Set Reference" manuals for the PLC-5 and SLC-500 controllers every day. They include detailed explanations of all the datatypes used in those controllers.
O0 Output
I1 Input
S2 Status
B3 Boolean
T4 Timers
C5 Counters
N7 Integers
F8 Floating-Point
