Allowing for bend radius
matlark
Jul 2011
KY
102
How far should the disconnect be mounted from the top of the enclosure when dealing with 250kcmil wire size? I know the bend radius which is 8x diam = 4 inches, but how does that translate to distance from where the wires enter cabinet?
It is very dependant on the insulation type of the cable as much if not more than the wire size.
Some insulation is more flexible than others. What tepe of cable and insulation.
I think this is great news! After many years waiting for it, I'm happy we have User Defined Structures for the Productivity PLCs. For those not...
18
6,794
Hi guys, Currently on a job. Trying to get a card to connect. An issue we believe is the solution is to change the cards general settings from...
1,419
An operator called me this morning. He said that he can't make any changes to fields on the panel view. It sounded like a permissions issue. So I...
1,677
I guys. I have a Beijer T12 panel that was developed by someone else. The trending is only allowing the last 48 hours to show. All the curves...
1,422
We are just moving from Step 7 5.4 Pro and WinCC 2008 to Step 7 V11 TIA portal. In the past we have shared one simatic project on the network...
6,179
