Analog expansion module for ML 1500
advmin
Mar 2023
Sheffield
59
Good morning Guys,
PLC: micrologic 1500 LRP 24bwa c series
soft: Rslogix 500
We are required to consider the weight of the product in such a way that, when a particular weight is reached, the plc should stop the process.
For that, we are planning to use loadcell, but the output is analog.
I didn't have any analog modules with my plc (7 digital inputs and outputs modules right now).
In the documentation, it says that max of 8 i/o modules can be added with the base.
1. Which analog module should I use?
2. Do I need to configure it manually or just by clicking "read I/O config"
after installing ?
3. Any other suggestions to use analog inputs without purchasing an analog
module for the load cell?
4. I saw a power distribution issue in the documents, Does that cause any
problem if I install the module in the 8th position?
slot no module
1 1769 sdn
2 1769 sdn
3 1769 iq16
4 1769 iq16
5 1769 iq16
6 1769 iq6x (6 i/p , 4 o/p )
7 1769 ob16
8 vacant
cheers.
I've not spent much time on the Micrologix range so I won't confuse things by commenting on that, but I can see two alternatives here.
1. Many load cells have a relay output which can be programmed to trigger at a set point, so this may solve the issue if it's a consistent setting.
2. Monitoring relay to achieve the same as idea 1.
https://uk.rs-online.com/web/p/monitoring-relays/1113090?gb=s
Does your current load cell amplifier have a network connection? Which protocols does it use? I've done this before with a DH+ to Modbus converter or EIP to Modbus serial converter to get weights into the PLC program (PLC5 and CPX).
If going the analog route it'll be a 1769-IF8 or so.
1. Many load cells have a relay output that can be programmed to trigger at a set point, so this may solve the issue if it's a consistent setting.
Thanks for your reply. Unfortunately, it's not consistent and the client needs almost 30 to 50 different weights.Plc needs to act differently for different weights.
Thanks mate.no other protocols are available for this one, only the analog route is an option.
So 1769-if8 or 1769-if4 would be the better choice.
cheers all.
Where is your power supply located?, as some analog cards have to within a certain number of modules from the power supply.
From series B on you could have 16 IO modules, I think you then need extension end caps and another power supply for the next bank of IO.
Thanks, Alan for the reply.
The 230/120vac power supply is powering the PLC and after referring to the ML 1500 documents, I found that up to 16 i/o can be installed and a maximum of 8 can be installed along with the base/processor and there is a power distribution calculator just before the glossary section in ML 1500 document which will help us to calculate the power distribution required.
cheers, all.
Years ago, I used a Hardy Instruments 1769 module designed for weighing applications that did a ton of the work for me and wired directly to the load cells. Mine was a CompactLogix PLC, but I think they can be used with the ML1500 too, just without the handy dandy UDT/AOP.
https://www.hardysolutions.com/hi1769
It's more expensive than a regular analog card, but can pay back some of that time in reduced code development. My application was an inline case check-weigher, (load cells affixed underneath a short, moving conveyor belt) so it needed to be fast and that module is awesome for that sort of thing.
I used their C2 series load cells and summing board too, which made setup and calibration a cakewalk.
OkiePC: ++++++
I'd add ML1500 is obsolete, so I will not spend any money on it.
C2 technology from Hardy is excellent, they even have a network exclusively for load cells up to 32.
I forgot to mention that if I were in such situation, I would move to compactlogix.
Having some trouble with getting data from this expansion module: I'm not sure what I'm missing here. No matter how many volts are being put...
3,257
well am using em231(4 inputs) with s7-200 cpu 222,AIW 2 suffered high voltage for a temporary time (milli seconds,before the circuit breaker...
2,291
I currently need some assistance for a PLC project that I have. Currently I am taking a PLC course that hasn't been very fruitful, but have found...
2,818
GREETINGS; DOES ANYONE HAVE EXPERIENCE WITH BRINGING IN A 4-20 ma TRANSMITTER, THAT HAPPENS TO ALSO HAVE "HART" PROTOCOL INTO A 1791D-N4CV2X...
5,896
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
115
