analog input cards
What is the failure mode ?
Card produces diagnostic interrupt ?
Card gives a fixed value for varying voltages ?
How long between failures ?
What equipment is the card connected to ?
Can you post a schematic ?
Have you worked out what is causing it?
We have been using S7-400 cards since 1997, with few failures.
What is your application?
Given the lack of detailed information, this is a wild guess, but incorrect earthing can often cause problems with Siemens I/O cards (at least with the 300 Series).
What is the Belden number for the correct wire to use when wiring analog devices to Allen Bradley Analog Input Cards? I tried to look at some...
3,190
Guys, looking for some help at a customer site... I need to add open wire detention to a system using 1794-IE8 and 1734-IE4C modules. For the...
4,768
I am working on a SIL2 system with a control logix, and refering to control logix documentation, to achieve SIL2 each Input Discrete or Analog...
4,673
I am using an Siemens SM 331 analog input card (314 CPU). I am noticing about a 0.1% error on the A/D conversion. Is there a way to adjust this...
6,721
I am haveing trouble understanding the difference between the 4-wire analog card of the siemens series plc and the 2-wire analog cards. From what...
6,408
