Analog input data display question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I have an RTD analog input module and wanted to know if it is possible to change the way the input module value appears on the ladder? The reason I ask is: I have a Quick Panel HMI that displays the value of an N: file from a SLC 5/03. It displays 111.5, for example, and I would like it to display 111, without the .5. I changed the HMI sofware to display only 3-digits, however, it reads 115 as opposed to 111. I checked the configuration settings in the book for the module (1746-NR4)and there doesn't appear to be a way that I can have the .5 dropped from that input. Any help one of you folks could be would be greatly appreciated.
A N file value shouldn't have a decimal point in the value. Could it be a setting in the Quick Panel.
If the N value is 1115 then you can divide by 10 then use the ABS instruction to drop the decimal point
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
285
I have a strain gauge attached to a load cell. The strain gauge is wired into an analog channel on a ControlLogix 1769 controller at +/-10V. How...
2,435
I am noticing odd behavior with a CompactLogix PLC I have here as a test unit. I have absolutely no I/O wiring on this unit, I just use it to...
2,088
I have a backup scanner 1747BSN which connects through RIO to adapter 1794ASB. I also have 1794IE8 analog input. What i would like to know is how...
2,041
hi I have to take average of my analog input data from analog input module FX 2N-2AD using with FX1N plc. As I cant treat REAL NUMBERS in FX1N...
2,041
