analog input programming
aryautomation
Nov 2006
texas
34
I am trying to measure a DC current going through a DC motor. I have installed mlogix1500 with an analog input card and 0-10 volts current transducer. This is the first time I am programming ml1500 analog input, I am not sure what I need to put in the logic diagram to capture the data. Any help will be appreciated.
Questions:
What analog input card are you using ( Module Cat no.)?
What does the 0-10 volts from your current transducer represent?
i.e.
0 volts=0amps
10 volts= 10amps
Or?
See Pictures below. I used engineering units for the data format, but there are other formats ( you decide whats best for you.
This gives:
4ma=4000 (raw data)
20ma=20000 (raw data)
You said in the first post you wanted current but in the last post you stated voltage? The scaling instruction will be the same, you might have to change the min/max values.
I put the instruction that you gave me. I am getting a warning that I do not understand.
SCP floating point operands are only valid for Micrologix 1500LRP/LSP series C FRN7 or higher....
What that means? I am using micrologix 1500 with LRP series C.
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
294
This is my first Siemens PLC programming. I got a PLC 315-2DP with 1 DI, 1 DO and 1 AI modules. I have already configured the modules and then...
10,593
DEAR ALL, PLEASE KINDLY HELP ME, TO WRITE PROGRAM FOR ANALOG INPUT(4-20mA). I AM USING MITSUBISHI PLC FX3U-4AD-ADP MODULE. PLC SOFTWARE IS GX...
7,599
Can someone give me a programming example of an analog input using Simatic manager. I am using CPU 314 IFM. Im need to get a 0-10 vdc input from a...
18
14,976
Hello , i would like some help on how to program analog inputs , 4-20 ma , 0-10vdc using slc 500's......if anyone could show me as far as do you...
2,291
