Analog input read (Beginner)
lbeh
Jul 2014
milwaukee
Hello,
I originally signed up planning on asking for some advice, then figured it out on my own. But since I am here and used this site frequently not as a member I want to continue as a member.... any ways.
I am going to attach a file for reading analog inputs using a micrologix 1100 controller and a 1762-IF4 input module.
The program simply reads a voltage from a power supply, and if the voltage is too high for longer than 10 seconds it latches on an indicator until an unlatch push button is enabled.
Just want to post this because very simple analog input examples were hard to find. Additionally any feedback about improving the program or my posts is appreciated.
Thanks, this site is great.
ok thanks. The program was just to familiarize myself with analog inputs. Eventually I'll be getting an RTD module and monitoring some dyne temps, so not really an issue. Thanks for the response.
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,010
Hi everybody Does anybody have experience with the Analog input card 1746-N18? Cannot get the last 4 inputs (4-7) to work like the first 4 (0-3)...
2,981
Hello, I'm working with a 1747-NI4 analog input module (for the first time) on a SLC503 processor. I noticed in the IO configuration within...
4,774
Hi, I need some help reading the value of Channel 0 of a 1769-IF4 card. The analog card is in slot 1. So the Input value should be...
3,949
hello.. i wanna add the value of an analog input value to the PLC existing system in my plant, i use OMRON CS1G-CPU45 and the analog input module...
3,694
