Analog input value range in decimals in mitsubishi .
ahsan1820
Jan 2012
karachi
22
Hi
what will be the value shown in the analog address memory read by PLC if I have 4-20 mA or 0-10v sensor signal,will this be 0 to 32000 Decimals?or 0 to 64000dec ?
32000 is for 16 bit data
64000 is for 32 bit data am i right?
so please tell me how can i set my scale upper and lower input limit???
please tell me for mitsubishi MELSEC series plc and GX developer as well for GX IEC developer software,if any difference in reading.
I think the resolution will be defaulted at 0-4000 for a digital value but what you need to do is go to mitsubishi's website and download the manual for the analog module you are using. You will need to enable and configure each channel and the details on how to do that is in the manual. You can select a different resolution if you want but it will depend on the setup written to the buffer memories.
Hope this helps,
Dave
16 bits means 2 the power 15 means 2 multiply by 15 time (with 0 bits)
2x2x2x2x2x2x2x2x2x2x2x2x2x2x2=32768
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
I ran into a strange issue the other day. System has been up and running for many months. An analog input channel suddenly reported 0mA. I...
21
3,306
On a Click PLC...How do I write the logic to totalize an analog input (water flow meter in GPM)? I need to totalize the gallons per minute input...
8,891
We have L72 controller of Rockwell make with 4 nos. analog inputs from pressure transmitters. Due to break in cable connection OR transmitter...
2,075
Hi everybody, I inherited a redundant 1756-L71 ControlLogix system with 2 racks with some DI, DO, and AI redundant modules (1715 series). The...
2,423
