Sadiq Al Zaman Member S Join Date Feb 2013 Location karachi Posts 17 Jul 12, 2013 #1 I want to know which analog module should I select for my 3AI and 1AO for my project , can i get both analog IO on a single card or module (i m using the mitsubishi FXon 24 mr ) , and recommend a economical solution , thank u
iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Jul 12, 2013 #2 the variations available are FX0N-3A = 2 In and 1 out FX 2N 2DA 2 out FX 2N 2AD 2 in FX 2N 4DA 4 OUT FX 2N 4AD 4 IN So the easy answer is no you cant there are specific temperature control modules incase you want to use thermocouples
Sadiq Al Zaman Member OP S Join Date Feb 2013 Location karachi Posts 17 Jul 12, 2013 #3 yes 2AI are acutually of temprature as a parameter (sensor used is PT 100) , so what will be the better option according to you sir ,
iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Jul 13, 2013 #4 http://www.mitsubishielectric.com.au/assets/IASW/melsec_fx_e_b.pdf This is the link I have gained the Info from I am not certain if this module works with the FX0N series Pages 53 onwards
Sadiq Al Zaman Member OP S Join Date Feb 2013 Location karachi Posts 17 Jul 13, 2013 #5 thanks alot sir
