Analog Output on MicroLogix 1400 1766-L32BWAA
kennedy6277
Feb 2016
Kitchener
Hey I'm a student working on a project. I trying to control a 0-10V driver using the analog output on the ML 1400. To test and output I've been writing 32767 into the data table and my meter will read 0V. What am I doing wrong here?
Taken from manual:
<Description 1766-L32AWA/A, -L32BWA/A, -L32BXB/A
Number of inputs 2 single-ended
Voltage output range 0…10 V DC - 1 LSB
Type of data 12 bit unsigned integer
Step response 2.5 ms @ 95%
Load range Voltage output >1 K
Output coding (0…10V DC) 0…4095
Output resolution 12 bit
Analog output setting time 3 ms (max.)
Overall Accuracy
-20…60 °C (-4…140 °F) ±1.0% of full scale
Electrical isolation Non-isolated with internal logic
Cable length 30 m (98 ft) shielded cable
And is the controller in RUN mode ?
This isn't a deposition or cross-examination. Post some information and you can get some help. Just saying "I did everything right but it doesn't work" is unproductive.
Yes it is in RUN mode.I have tested the inputs (I0.0) and the the other outputs (O0.0) and they have been working fine. I have everything properly grounded.
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
673
I am trying to put together a program for a control valve and scale combination. I will be using a ML1100 PLC, a 1762-IF4, and a 1762-OF4. I will...
9,623
Hi all, i am trying to setup a AB micrologix 1500 with analog output card 1769-OF4CI (4-20 mA output) using RSLogix500 and it detected as other...
8,942
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
319
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
