Analog Panel Meter
ndzied1
Aug 2002
Chicago, Illinois
2,857
Where can I get a decent quality analog panel meter with a needle (customer specification). This is to display an analog signal from a VFD. They want the face to just read 0-100%
Thanks,
Norm
Try an electronics distributor like Newark
http://www.newark.com/jsp/search/br...cale=en_US&catalogId=&prevNValues=2203+201271
Issue is matching signal that drives the meter with what you've got. The link is for 0-20mA DC, but there are numerous other AC and DC/volta/amps ranges.
Simpson used to be in our backyard - Elgin, IL. The former Simpson building was largely abandoned when I went through it 3-4 years ago, except for about 1500 sq.ft of space for administering asian contracts.
Thanks for the links. I had actually thought of Simpson first. What I can't figure out is how difficult or expensive it will be to get a face that has a scale that reads 0-100% and not some voltage or current reading.
Thanks again,
Norm
you could use a 0 ~ 10V dc meter
simply re-lable the Volt to 100%
as the drive output is settable to 0~10V
I love the look of the Otek units. As a distributor we usually have to stick with brands we represent but I have used them on occasion.
They were also fairly easy to work with for specifying part numbers and getting technical information.
How do you guys wire your 2 wire with a shield connections. Mainly I am talking about wiring up the shield wire for field wiring coming into the...
2,439
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
596
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
70
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
148
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
212
