Analog Panel Meter
ndzied1
Aug 2002
Chicago, Illinois
2,857
Where can I get a decent quality analog panel meter with a needle (customer specification). This is to display an analog signal from a VFD. They want the face to just read 0-100%
Thanks,
Norm
Try an electronics distributor like Newark
http://www.newark.com/jsp/search/br...cale=en_US&catalogId=&prevNValues=2203+201271
Issue is matching signal that drives the meter with what you've got. The link is for 0-20mA DC, but there are numerous other AC and DC/volta/amps ranges.
Simpson used to be in our backyard - Elgin, IL. The former Simpson building was largely abandoned when I went through it 3-4 years ago, except for about 1500 sq.ft of space for administering asian contracts.
Thanks for the links. I had actually thought of Simpson first. What I can't figure out is how difficult or expensive it will be to get a face that has a scale that reads 0-100% and not some voltage or current reading.
Thanks again,
Norm
you could use a 0 ~ 10V dc meter
simply re-lable the Volt to 100%
as the drive output is settable to 0~10V
I love the look of the Otek units. As a distributor we usually have to stick with brands we represent but I have used them on occasion.
They were also fairly easy to work with for specifying part numbers and getting technical information.
How do you guys wire your 2 wire with a shield connections. Mainly I am talking about wiring up the shield wire for field wiring coming into the...
2,434
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
121
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
134
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,177
