Analog transfer
metalsiren
Mar 2007
Tampa
I am new to PLCs. I have RSLogix 5000 software, 1769-IF8 Input module, 1769-OF4VI output module, and 1769-OF4CI relay output module. I have connected 4-20 mA and 0-10 Vdc going into 1769-IF8, 0-10 Vdc coming out of 1769-OF4VI, and 4-20 mA coming out of 1769-OF4CI.
In my ladder logic program, I need to transfer those 2 analog inputs to my outputs. Will the MOV function block suffice what I need? If so, do I need to worry about scaling if I only want to transfer? Also, will the transfer be continuous or do I need to loop it?
Any help would be much appreciated. I am glad in becoming a part of this community.
How do I set the scales? In 1769-OF4CI, I want to output the 4-20 mA. Do I set the limits 0 for Low and 29085 for High; it says it's maximum value is 29085.
In 1769-OF4VI, I want to output 0-10 Vdc. Do I set the limits 0-29788?
Am I on the right track?
As for the input, 1769-IF8, is the scaling set by the alarms? If I do so, I keep getting Alarm limit invalid, and it must be set to 0.
I would like to enquire for a product as a solution for our on-going project. We need to transfer some analogue signals (QTY:08 / 4-20mA ) from...
3,900
I've got a SLC with a RIO scanner 1747-SN and a flex IO DIN rail 1794-ASB with an analog output module 1794-OF4I Now I've found example code etc...
2,342
Hi All, First time caller, long time listener... Have a new system in the field with a new controllogix 1756-DHRIO talking to 6 existing chassis...
5,803
Hi guys ' Can anyone help with the problem of configuring an analog input module (1746 NI8) using block transfers (BTW) . I have a SLC 5/05 CPU...
5,696
analog blocktransfer for a rio module would like a example this is for a slc 500 processor using a scanner module to a rio rack 1794 taking in...
3,601
