Analog value change
mahathir
Jul 2009
Shah Alam
Good day all,
I have some issue with Analog value, i use A68AD analog module (Mitsubishi A-series), refer to my attachment, why the D32 value change from 72 to 1441864 in the next ladder?
How to convert it to real value?
Hope anyone can help me on this matter..
You are doing a 32 bit multiplication. Is there something else in D33?
If you are not using D33 somewhere else, try to change the FROM command that you are getting the value from to a DFROM command to make it 32 bit.
Hope this helps.
-Dave
Dear Dave,
I already try change the FROM to DFROM command, then when i try convert on-line change,there some pop up window indicate instruction selection and instruction retrieval.
and D33 also use in other ladder.
i am sorry if asking basic question, but i am beginner level in PLC.
If D32 is used in another spot in the program than that is the problem. You need to change D32 to a data register that is not used and the next data register is not used either.
The 32 bit instruction is looking at both of the 16 bit registers D32 + D33 to make a 32 bit value.
Hope this helps,
-Dave
I am working on bottle testing machine. for that I am Working on PLC allen Bradly 1400. now I am applying pressure in bottle and i have scaled...
1,705
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
261
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
297
Apologies if this is a basic thing to ask here. I am controlling an Analog control valve. I need to open it for 100%. At this Juncture PID is not...
775
Hi Guys, I'm working on a Lintel Test Machine control application with AB Guardlogix PLC, which involves Pressing Lintel Sample and monitoring...
1,705
