Analogue datalogger with internal scaling
DLMUK
Jun 2013
Southampton
311
I have an application with a load cell where I need to log the load cell output, into a small/internal data logger. But I also want the values to be scaled within the logger.
I.e.
- the output from the load cell to the logger is 0-20mV
- the logger scales this 0-20mV to 0-12tonnes and records the value
The input signal can be either mV/mA or 0-10V.
Does anyone know if such a device exists?
Thanks,
How often do you need to log the information?
Where do you plan on storing and retrieving the information?
The most flexible method is to use a small PLC. I would use a Click from Automation Direct.
https://www.automationdirect.com/adc/Shopping/Catalog/Programmable_Controllers/CLICK_Series_PLCs_(Stackable_Micro_Brick)
The analog are scaled in the setup of the unit and be stored in the PLC memory for retrieval.
The retrieval of the data can be done with Modbus TCP using AdvancedHMI. This is a free package.
https://sourceforge.net/projects/advancedhmi/
Here is a free programming series on the Click which also includes communication back to AdvancedHMI.
http://accautomation.ca/click-plc-system-hardware/
http://accautomation.ca/modbus-tcp-data-logging-to-database/
Hope this helps you out.
Regards,
369
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
93
I am using Mitsubishi PLC :FX3g and downloaded the program in it. When I connect Mitsubihi FX2N-4DA expansion module, it lost its communication...
267
Hi All, I am working on a small PLC system having Compact Logix LE33 PLC having only two IF4 card. Some of these channels are used for 4 - 20...
1,166
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,022
