analogue input to plc
hala-whab
Jan 2015
khartoum
hello everyone !
My question is simply how to read an analogue input with s71200? and what is level sensors that you recommend me to use to read the level of the tank ?
Thanks,
How to read it?
First wire it to the s7-1200 CPU or EXP, then you get the value in TIA portal and can manipulate it.
This particular problem is doing my head in... In our system we have a minisonic flowmeter. One of these. It outputs 4-20mA and is an input into...
1,420
Hi all, I need some advice on an Analogue Input on a Phoenix contact PLC inline control ILC200IB. The machine it as attached to is a Jensen...
5,072
416
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,028
Hi, I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match. The supplier is saying the channel needs...
766
