Q Series analogue input - change to passive
Tjkeets90
Mar 2018
England
39
I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match.
The supplier is saying the channel needs to be active and not passive.
I am using GXWorks2 and have looked through all the settings but can not find any reference to passive or active.
Has anybody changed this before?
I presume that it is about wiring, not about software configuration. Do you have 2-wire sensor?
It depends on the Analogue card, some have power (24V) some do not.
Generally for a passive sensor (2 wire) then you put +24v onto the + of the sensor, the -ve of the sensor then goes to V+ & I+ on the card, the V- on the card goes back to the 24v supply 0V or -ve,
So in actual fact, the sensor then becomes active.
If it is a 3 or 4 wire sensor then the power is fed to the + & - of the sensor the out & - of the sensor (two wires) is fed to V+ & I+ (together) & the - is connected to the V-
Hi, I'm planning to install a new Analogue Input module Q68AD-G. It will inserted on Rack 0 Slot 4. When it's installed, will the code recognise...
2,434
Hi, I've got a Q68AD-G card (8 channel). I want to configure it for 0-10v analogue input. I've enabled the channel by using Un\G0. Then I used the...
1,837
Hi, I've run out of analogue input channels on my Q68AD-G module. If I add a new Q68AD-G module and install it into a spare (blanked-off) slot, it...
1,338
As per title, looking at how to scale an input, 4-20mA to a real value. Taking it in as an integer (RAW data)and converting it to a real, being...
2,031
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
