Ani-Virus Software vs Rockwell Software
daba
Jul 2004
uk
5,401
Had an issue that started last Friday where my Anti-Virus software, AVG, got updated, and since then Rockwell software activations have ceased to work.
It is definitely AVG, turn it off, my RS products work, turn it on, No activations found.
AVG themselves don't seem to be able to fix it, even though they rolled-out the updates that broke it.
I think AVG is just putting up every shutter it can, and at the same time advertising more software to make your PC even slower....
I might just ditch AVG, and go with another. What do you guys use to protect your PCs
ZoneAlarm Extreme, no issues with AB but looking at moving away come renewal as it's windows only.
Have a WatchGuard on the ISP incomer but it's a physical box (Firebox T15).
Just started testing with MalwareBytes Pro, as a replacement to ZA with the T15 covering the Firewall essentials. So far so good.
RA tell me that everything they provide is tested with MacAfee, so thinking of switching to that, but is MacAfee as good as AVG ?
Lol, I think I have just answered my own question ...
We are using ESET. There was a time when I used to use some of the free ones like AVG or Avast, but a great many AV's are so cheap now that you may as well pay the small amount.
I haven't used AVG for a number of years. Do they have a facility to create exceptions?
I was about to suggest this before I read Jeev's post.
I use TrendMicro's Virus Buster and this software does have a menu where one can list those applications that I would want to be left alone by the Virus Buster.
It makes no difference if the activations folder is in the exclusion list or not, Activation Manager cannot "see" the activations either way.
I have also added Activation Manager to the list of allowed programs, and that makes no difference either.
Currently AVG Tech Support is closed, due to the current pandemic, and they are in the process of setting the support guys up to work from home, but they have not yet got remote access.
Strangely, the activation for RSLogix500 does appear in FTAM, but it takes a long time to do so. This is the only activation I have that is "Concurrent", all the others that never appear are "Node-Locked". I find this weird, as the activation files are just plain-text files....
I left AVG years ago because they did not honor the exceptions list entry for a specific application that I used. I gave them three years to fix it!
Hi Daba,
This technote...
ID: BF13983 | Access Levels: Everyone
FactoryTalk Activation Manager: FlexNet Stopped
...about half way down it mentions...
BF13983 said:
...For testing purposes, disable your antivirus software and refresh the activation server. If you find out that the server state changes to Running and doesn’t go back to FlexNet Stopped please add Rockwell software to the antivirus exceptions list.
Note: This has been seen with AVG antivirus software...
It then links you to another technote...
ID: PN826 | Access Levels: Everyone
Security considerations when using Rockwell Automation Software Products
...which "should" have a PDF attachment with all of the necessary information for adding exceptions to Firewall/AVG. But it does not (get to that in a second)...
Also in the first technote, it says...
BF13983 said:
Note: Even though the exclusions list includes activation-related services (FactoryTalk Activation Helper/Service, Codemeter etc.), this procedure was made with Studio 5000 in mind and includes Studio 5000 processes. It is recommended to add this list completely.
So, whatever it is they tell you to add to exclusions, it will likely be more than you have been adding?
As that PDF attachment is missing in the "fancy newfangled whoopdeedoo" support layout, I contacted Rockwell via Chat using the free Activations Support option, and a very helpful Wiktor promptly emailed me the PDF file that's missing...
Chat By Chat (Wiktor) (04/02/2020 09:49 AM)
[09:42:16 AM]Hello, welcome to Rockwell Automation. My name is Wiktor. How may I assist you today?
[09:43:34 AM]George: Hi, https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/609492 [rockwellautomation.custhelp.com] The file attachment is missing (PDF). A colleague requires it to add exceptions to AVG antivirus as it is currently blocking FTActivations from seeing available activations.
[09:44:06 AM]Wiktor: please give me a minute
[09:44:36 AM]George: No problem, thank you.
[09:46:07 AM]Wiktor: george...@... this will be good mail to send it to ?
[09:46:22 AM]George: Yes, please, thank you.
[09:46:46 AM]Wiktor: please check your mail
[09:47:48 AM]George: PDF received, thank you very much Wiktor.
[09:48:28 AM]Wiktor: you are welcome
[09:48:35 AM]Wiktor: is there anything else i can help you with ?
[09:48:56 AM]George: No, thank you, you have been most helpful and prompt.
[09:49:09 AM]Wiktor: have a nice day then and stay safe
[09:49:11 AM]'George: You too!
[09:49:13 AM]'George' disconnected ('Concluded by Agent').
Although I now have this PDF file, I cannot attach a link to my private copy of it here, as that is against Forum Rules. However, if you PM me I'm sure I can discuss its "contents" a little with you? Else, you could also use Chat support and do as I did? It took no more than 10 minutes, as you can see.
It is worth having this file as the list of Rockwell "things" that need made exception of is quite lengthy and, I'm sure, may relate to more than just one brand of Firewall/Antivirus.
Regards,
George
I have been using Windows Defender for many years.
For me it is enough and slows down the PC far less than McAfee or other famous antivirus
I have read posts here about people hating AVG or Avast and switching to the other.
I have each one a computer and can definitely state that, other than the window color and graphics, they are the same program.
The menus and settings are all worded the same in the same order, with the same options. So, I think the A in AVG stands for Avast V.G.
BTW - I just bought a new Xidax PC that came with ESET mentioned above & it is really an improvement.
If am trying to animate the text color @ diff ranges, (0-200 yellow,201-299 green, 300-500 red as an example) could i do it by writing an...
1,536
Salve ragazzi... questa volta non so proprio da dove iniziare... ho bisogno di un immensa mano.ù volevo sapere cosa si deve fare per risanare il...
2,677
I had an old boss reach out to me last night. He mentioned that their system had a huge virus that did all kinds of damage to their servers. They...
4,188
Good Afternoon, Every 2 months we have a county wide Manufacturing Roundtable at a local college , but now it’s a Zoom conference now . We...
17
5,657
Here's another puzzle to take your mind off the current situation. Attached is some structured text that flashes the variable 'Flash'. A small...
2,267
