ANY data typ
martin3885
Aug 2005
Saarland
144
I try to work with ANY data type. I read in Step7's help about it, but there is no example how to use it. Yesterdy I found this thread. RolfB has placed there an example with ANY data type.
FUNCTION FC 15 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
in_PDatabase : ANY ; // Sample P#DB15.dbx0 Byte 1
in_iBitoffset : INT ;
END_VAR
VAR_OUTPUT
out_Result : BOOL ;
END_VAR
VAR_TEMP
P : STRUCT
Kenn : BYTE ;
Typ : BYTE ;
lenght : WORD ;
DBnum : WORD ;
Bereich : DWORD ;
END_STRUCT ;
END_VAR
BEGIN
NETWORK
TITLE =Copy Pointer in local structure
L P##in_PDatabase; // Any-Pointer
LAR1 ;
L B [AR1,P#0.0]; // ID S7
T #P.Kenn;
L B [AR1,P#1.0]; // Data Typ
T #P.Typ;
L W [AR1,P#2.0]; // Lenght
T #P.lenght;
L W [AR1,P#4.0]; // DBno
T #P.DBnum;
L D [AR1,P#6.0]; // Area
T #P.Bereich;
AUF DB [#P.DBnum]; // open Datablock
//add Bitoffset to pointer
LAR1 #P.Bereich; // Area --> AR1
L #in_iBitoffset; // INT add Bit Offset
+AR1 ; // to -> ar1
U DBX [AR1,P#0.0]; // Sample ?=1
= #out_Result; // Test if function work
END_FUNCTION
Do I always need such a "P" structure?
What if I want to point to FB and not DB?
I would be thakfull if someone could show me another example with variable of ANY data type, thus I could compare them and see how does ANY data type works.
If I do Help on STL from the block editor (using english) and find topics related to any, I get the following:
Example of the Data Type ANY from the topic ANY_PTR. This shows a coding example using any pointers.
thanks, I found it.
Simon, maybe you will know this, no, you know everything, so you must know also this:).
In my book there is that ANY-Pointer cannot be used in AWL(STL), because it has 80 bits and it is longer than accumulator.
But in Fact we do use ANY-Pointer in STL.
So, how should I understand it?
I refer to my Hans Berger book for information on any pointers etc. I'm sure it must exist elsewhere in the Siemens documentation but as I have Berger thats where I always look. From the content of your posts, I strongly recommend you obtain a copy....(do a search on this site and you will find the ISBN)
Just for info, I have created an FC that will return the individual components of an any pointer, see below. For example, you can call FC3 and specify FC3 as the parameter for pAny, this will show you how Step 7 has coded this as an any pointer.
Code:
 FUNCTION FC 3 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  pAny : ANY ;
END_VAR
VAR_OUTPUT
  byId : BYTE ;
  byType : BYTE ;
  iSize : INT ;
  iDBNumber : INT ;
  dwPointer : DWORD ;
END_VAR
BEGIN
NETWORK
TITLE =get individual components of an any pointer
	  L	 P##pAny;
	  LAR1  ;
	  L	 B [AR1,P#0.0];
	  T	 #byId;
	  L	 B [AR1,P#1.0];
	  T	 #byType;
	  L	 W [AR1,P#2.0];
	  T	 #iSize;
	  L	 W [AR1,P#4.0];
	  T	 #iDBNumber;
	  L	 D [AR1,P#6.0];
	  T	 #dwPointer;
END_FUNCTION
Please excuse my ignorance,but why would you want to call a FC as a Parameter for a any Pointer?
Is there a Practical application or example for this to help me understand? I've seen it applied as follows call FC [FC_NO] but nothing more complicated.
Thanks again.
Thanks!
jacekd,
thats perfect, Now the small problem of understanding it all! Also thanks for the interesting alternative to the #LOOP_COUNTER in the other thread!
Regards
Sorry for hijacking the thread!
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
110
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
225
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
84
78
