anybus communicator
gasse
Apr 2011
france
hi all,
do you have an exemple of Anybus communicator configuration to communicate with a Maguire blender in rs232.
see my project example:
PLC <------->Dnet<----->Anybus comm<----<Rs232>----> Maguire
My devicenet configuration is OK no fault but no data come out of the anybus to the Maguire.
sommeone have ideas???
thanks,
Bon Jour,
Have you tried to log any communication? In ABC Config Tool - Tools/Start Logging. If you do have any communication, it will be shown under TX alt. RX in the log file.
Post more info, else I cannot help you further..
Patrick Lansdorf
FAE
HMS Industrial Networks
re
bonjour,
In tools/start logging popup, I only data that I send ( from device Net ) but no the Maguire response.
May be the maguire does not understand the Anybus signal or my configuration is not right.
Can i send to you my Anybus configuration file to examine.
Thanks you
Red Lion has a Maguire driver built-in. You should consider using it for your comms gateway. With a DeviceNet slave card, the DSPSX could be just the product. I don't know about the Anybus product supporting Maguire comms.
Thanks,
Joe_WaZoo
Complete novice trying to integrate an industrial fluid filling process into MES using an anybus communicator Hardware: Anybus Communicator...
1,594
Hi everyone. I have just received a second hand AB 7000 and am attempting to download a configuration. Its requesting a password which i dont...
2,187
Hi all, I am trying to configure a Siko field bus actuator...
7,568
My local distributor is pushing a product called Anybus Communicator which is supposed to interface DF with EthernetIP (among other things). I'm...
2,732
Need help connecting CPU 313C-2DP and AnyBus ABC-PDP commnicator ( Profibus). Maybe somebody have tested program for STEP7, which just reads 1 word ?
4,426
