Anyone use a 6ES7972-0AA02-0XA0 485 repeater
I have used them, alot... They are usually used to increase the distance of a DP segment. They can be used for DP or MPI, depends on the network. I have used a dedicated Siemens PG to connect or a Siemens serial to DP converter, never tried a USB version.
Is your customer using Step 7 or TIA portal? Did they select the correct interface from within the software? How does your device usually show up in the list?
Thanks Ken,
He is using Siemens Starter Commissioning Tool, my cable shows up as a Profibus, see below, this is his screenshot
I will also ask him to join us here
I received an email from a student with the following code attached. This is supposed to control a floodgate system, and supposed to be written...
23
783
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
89
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
132
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
237
