ARCOM RTU <--> Modicon PLC Interface
kaziz1977
Aug 2003
Has anyone come across Arcom RTUs interfaced with a Modicon PLC or any other RTU/PLC system? I need to consider options to upgrade our existing, around 70, RTUs which will no longer be supported by the manufacturer in the near future.
Thanks for your feedback in advance. :unsure:
Confused?
Maybe I don't understand your situation, but have you contacted
Arcom Controls about replacements? I am not trying to be funny or anything, but if the RTUs are about to be obsolete, then it seems Arcom would be a good place to start in trying to find compatible replacements. Just my opinion.
p.s. I have not ever used RTUs so I am not going to be much help past this point.
Thanks for you reply. Well the thing is that I would like to look into other options too, other well known brands like Modicon or Bristol Babcock. Besides, Arcom do not have the same type of equipment which was previously provided to us.
Another advantage of moving away from one manufacturer is that a level of flexibility is obtained in the system, although there may be some teething problems with the communications setup.
Thanks,
K.Aziz.......... ;)
Hello Azis,
I came to this thread by searching on Arcom RTU. I like to know what happen then with your replacement plan.
I have similar case here using Arcom RTU and like to migrate to Modicon PLC.
Thanks in advance.
Edy Sucipto
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
115
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
485
