Are FactoryMation and Automation Direct Breakers good?
Plcdude2021
Aug 2021
Matrix
I'm thinking about using either in an upcoming project and I was wondering if anyone here had any experience with either. What are your thoughts on breakers from either place?
Some of the breakers @ Automation Direct are Eaton, even the big molded case breakers that say Automation Direct on them.
I use Eaton breakers all the time
When I used to work for Automation Direct we sold Eaton direct and private label as well as Fuji. I think everything labeled automation direct now is Eaton.
Anyone ever heard of FactoryMation (http://www.factorymation.com)? Just saw it in an IEN and it looks to be nearly identical to AVG's...
2,281
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
57
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
88
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
211
