Are there any EthernetI/P barcode printers yet?
James Fillmore
Sep 2004
Detroit, MI
45
Sheesh. Been doing the Zebra or Sato serial port thing. You would think there would be and EthernetI/P version already from one of the big manufacturers or have I just not found it yet.
I haven't come across any that are ethernet/IP yet however this does not mean they are not available. I have however used serial to ethernet converters with barcode scanners in the past.
Call Real Time Automation They have a serial to EIP adapter that doesn't require any special setup in the PLC just write to a tag in tHe PLC and point the RTA adapter to that tag. I don't do serial anymore without one of these. If you count your time at $0.00 an hour you would still be money ahead to use one of these adapters.
Don't get all huffy, James... I see at least two options above that will work.
Call Real Time Automation They have a serial to EIP adapter...
This one actually appears to open up the whole world of ethernet printers:
I have done three systems printing barcodes on Zebra printers over Ethernet using Contrologix and EWEB cards.
Good Day all, I have a site where I'm using a Compactlogix L33ER Version 21.11 to connect to a Wiedmuller U-Connect I/O Rack setup using the...
2,430
Hello all, I am trying to poll data into a MicroLogix 1100 from a PLC 5/40E over Ethernet I/P. My MicroLogix program contains a single message...
5,495
We have added a new feature to our latest motion control product. Our new product can do EthernetI/P I/O or implicit messaging at 1 millisecond...
2,573
Hi, We have developed a CIP(Ethernet I/P)driver using which my program in a PC can communicate to ControlLogix PLC through 1756ENET card. Can I...
2,449
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
64
