Good Day all,
I have a site where I'm using a Compactlogix L33ER Version 21.11 to connect to a Wiedmuller U-Connect I/O Rack setup using the Generic Ethernet Device, It's been installed and working fine for several months, however for some reason last night the PLC lost connection to the Remote I/O Rack. I was wondering if there is anyway to use the Ethernet connection Status in the Ladder logic to enable a warning message, or shutoff related equipment when this happens, I know I could enable a Major Fault on the loss of I/o, however that would produce undesirable results on other systems. So is there a way to have a status bit to tell the PLC wether there is a good connection or not? I've attached a screen couple of screen shots so you can see the configuration of the module in question
Thanks in advance for all your help
