Aromat Low Cost LCD Touch Panel.
willpower100
May 2004
B.C. Lower Mainland Canada
81
I was looking for a low cost touch panel for an existing application, I need something with multiple screens. I came across the following units,
http://www.awc-direct.com/argtlowcos4t.html
Does anyone have any experience with these units and can give some feedback.
I dont need much in the way of graphics capability, I want to display analog input data and setpoints. I also want a cheap unit, this looks like the one.
The plc uses MODBUS, Ascii or Rtu.
I've used one thats similar , the gt 30 color screen, used with an AB 1200 micrologix, the software was easy to use, and our screen only cost us 950 Can.
Best Regards
Lab
The aromat screens are very good little screens. The GT10 is only mono though with different backlights, but you can have bitmaps. We had some problems with double integers not communicating to a sixnet plc via modbus properly, but the problem got sorted in an upgrade.
Does anyone know if there is an Panasonic Aromat PLC distributor in Portland, Oregon? Platt Electric used to be the distributor but isn't any more.
1,671
Hi All I am looking to buy the software and programming cable for a AROMAT FPG-C32T2 Plc and the same for a AROMAT AIGT3300B Touch HMI screen...
1,844
Good morning all: I have programmed extensively with many AB packages, many Omron packages, Idec, TI, but never Nais. I'm using FPWin Pro4. I'm...
3,451
I'm sure one of you fellow freaks know what I need. I have a NAiS PLC with FP2-C1 CPU. I need the programming software for this. The sites...
5,130
I would like some opinions on how well the Aromat FP1 PlC'S stack up against A/B or Omron. We are considering buying 5 of them for a sliding...
3,537
