Array help
notfet
Jan 2016
texas
I have 50 tags for alarms I only want to display 10 at a time using a Productivity 2000 PAC and the CPD instruction I called each one alarm 1,2,3 etc... at the first rung I cleared an integer to 0 and each tag the INC function by one. At the end I copy that to another tag and I have the alarm total. How does the ARRAY function work? I thought this may be a way to group them 10 at a time(boolean) so they can be shown in order. But I am not sure of how 1d, or 2d or rows and columns work. Even if this is not the right path for this problem can someone explain the ARRAY functions please? The help files and searches on the internet haven't helped me understand.
Maybe I should start from the beginning as what I have already is not an array. I have an CPD instruction with "text" as the source and alarm 1,2,3 etc... as the destination. What I think I want would be a 2d array like this,
Code:
        col1, col2
Row1---alarm1,1
Row2---alarm2,2
Row3---alarm3,3 etc...
I have created a 2d string called String_Index in the tag database but do not see how to get the data in the fields. Please help
Thank You
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,061
Hello all, I need some guidance creating a FIFO array to display data into an HMI. The data will be the sum of jams of a conveyor section in an...
2,701
hi, i try to capture barcode data using UDT with SINT ascii array. i have all the data i need but it in array format, how can i convert to 1...
3,080
Hello all, I'm working on my first project with an Allen Bradley Micro 810 using the connected components workbench. Everything is going well so...
3,175
Hello All, Needing some help with finding Min max values in an array that can have a dynamic element count. The Sort function in Logix 5K only...
5,721
