ASCII code for Micrologix 1100
sellis4003
Feb 2019
maryland
Hello, I am working with a micrologix 1100 allen bradley plc and I need to send and receive ascii code to a sensor device. The syntax for the commands that the manufacture states are the following:
set:LO=xxxx -(to set the low speed)
set:HI=xxxx -(to set the high speed)
I can get this to work using an AWA write command with a ACN command by typing the (set:LO=) in my ST string file and loading the xxxx variable from an hmi into and interger file and using an AIC command.
it works pretty well.
What I am having problems with is how to read information from the sensor.
get:LO=xxxx
get:HI=xxxx...
I am not certain how I can read these with and ARL or ARD instruction.. Or do i need to do something else. I will also need to convert it back to an integer file.
Thank you for your time!!!
Steve
Thank you Geoff for responding. Would I set the string file up the same way. Type the get:LO= into the ST string data file and use that ST address in the ARD instruction???
Hey Guys, I'm still having issues with reading the ASCII. I can seem to write OK but cannot seem to read anything by using a ARL or ARD instruction. I attached a PDF of the program. This is pretty much the example that Rockwell had on their website with a few modifications for the write instruction but I can't seem to get it to work. Any help would be greatly appreciated... Steve
Hi Guys, i am reposting this beacuse I'm still having issues with the "READ" ARL or ARD instructions. I have a pdf of a program that I found on...
1,971
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
727
hi, i try to capture barcode data using UDT with SINT ascii array. i have all the data i need but it in array format, how can i convert to 1...
3,057
Hi, anyone can recommend for*Melsoft for Q*series instruction to reverse the ASCII code i receive the eg. bacode ABC12345 i wanted to change...
1,862
I have an omron cp1le plc and a sato s84ex printer I need to learn how to send print jobs to it. I know I can use the Serial card option and send...
2,629
