ASCII READ Error 0Eh on Micrologix1200
Wiggum11
Nov 2013
Indianapolis
I have a micrologix 1200 and I am trying to get a barcode scanner to talk to the COM 0 port. I know the scanner baude rate is 9600 because I pulled it off of an existing machine. The scanner is plugged into a null modem and then and the other end of the null modem is plugged into a1761-CBL-PM series C cable which is plugged into COM port 0. I have this same set up on a couple of micrologix 1400's and it works fine.
I channel 0 set up as follows:
9600
Parity None
Termination1 \d
Termination2 \ff
Echo is not checked
XON/XOFF is not checked
I am using an ARD command as follows:
Channel 0
Destination ST9:0
Control R6:1
String Length 0
Characters Read 0
As soon as the rung goes true the Error 0Eh comes on and I never see the DN come on. I know this should be fairly simple because it works on my 1400's. Any ideas?
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,431
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,580
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,553
Hi all, this is the first time I have posted on here, I have been reading with interest for a few years now. The problem I have is regarding...
1,520
Hi Everybody, I need to know, how to programming read and write "Hex Value" to the equipment by port RS-232 "Ascii" (CJ1W-SCU41-V1 Unit ID.1) of...
1,063
