ASI Slave module Addressing Issue
pravinbhange
Feb 2008
Pune
I want wnt to know about addressing of ASI slave module. If I enter addressing in slave configuration of ASI Master, the addresses it tatakes randomly. e.g. 1st module take address 5.0 to 5.3. 2nd takes 6.4 to 6.3. 3rd takes 6.0 to 6.3. 4th 7.4 to 7.7 and 5th 7.0 to 7.3 likewise. I want to give adress serially. Pl.send me solution.
most of the timeif you connect nodes to a network .power the network and auto addressing is enabled it will assign an address to all nodes . if this is first start then they will be sequential . if adding a module it will assign the next logical address . the only way to assign a diffferent address is to enter it with a handheld programmer . auto addressing will not assign an address to a module that already has one . make sure not to use an address hat has already been used on auto addressing . this stands thru for most asi systems . most of my experience with then has been on ifm effector brand i/o and sst masters for slc and contrologix
Hi all, I am new to the whole As-i and S7 world. I added a 3RK1400-1DQ00-0AA3 41/40 Slave and configured it as slave 2 with hand held...
1,533
Hi, I want to know how to read and write to asi safe slave in Microwin. When the input is activated, in the program the contact begin switching ON...
2,345
we are using S7 300 plc and CP 343, But i don't know how to assign the ifm slave module in asi network
4,547
It is possible at all? I have an issue almost in accuracy same that I have found in official forum Siemens: oshaman wrote: "I have recently...
5,338
We use a DP/AS-Interface link 20E. This block converts the ASI network to profibus I/O. I need something to indicate an ASI slave is not working...
4,438
