Brian
SLC505 Processor. On a packing line we are using scanners to read a content SKU label on one side of the carton and another scanner to read the box code on the back side. This is collected and entered into ST:9 with a length of 22.
To count the number of cartons packed, we use a photo eye on the conveyor that is triggered when the carton passes, and we tie this into a plc counter and overhead digital display where the operators can monitor their production. In our logic, we are using the ASR to compare the scanned STRING information for changes. When the SKU information changed we wanted to automatically reset the display to zero.
Problem is how to deal with NO READ situations. We have discovered that if the scanners send a NO READ for the SKU or Box Code, then the PLC treats the no read as a new product and zero's the counters.
I'm reading into the manual (but new to this) and am drawn to the MEQ instruction. Can I use this to look for the NOR input? Can it even be used in a string? I see a lot of references to hex put don't but see it in the string file.
