ATEX HMI for Zone 2
theDave2
Aug 2004
Rochester, NY
467
Who makes an HMI touch screen that has ATEX certification for Zone 2? AB does not.
Stahl makes one, but if it has the same software as 5 years ago, I prefer not to use it as it was tough to use / debug.
Schneider looks like they have one as I've got a Power Point file that shows one.
Any others ? I don't need a lot of function, it's for just controlling / displaying a dozen things in one small area. And it should talk DH-485 / serial (or ethernet) to a CLX plc.
I wasn't clear.
That P&F unit looks to be a PC + software = $$$$$$
I'm looking for an all-in-one unit, not PC based, something like an AB PanelView or Red Lion G3 or AD C_more. An OIT.
I don't know what does Zone 2 stands for, but Allen-Bradley PanelView Plus terminals are certified for Class 1, Div II hazardous area. Hope it helps.
Class x, Div y is NEC USA hazardous area specification. Most other places in the world use either IEC Zone system and starting in 2003 the EU countries use ATEX of for.
Allen-Bradley PanelView & PV Plus are only rated for US NEC, not Atex.
QuickPanel which is now GE owned has an ATEX zone 2 HMI.
No part numbers right now, just seen it in one of their manuals/brochures.
I haven't used one.
Not sure what the Comm options are either (Profi, MODBUS, etc).
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
1,011
Hi, I have an application which is in an ATEX hazardous area, the instrument being used is lower power and qualifies as 'simple apparatus' and...
2,363
I`m searching for a remote mobil panel (battery driven), for controlling some IO on a PLC. The remote mobile panel need to be approved for Atex...
2,092
Hi all, i have to connect a panel that is located in an atex area. The patchcord that connects this panel to an outside switch should be a normal...
1,746
Hi all, Does anyone know of an ATEX 2/22 sensor that I can use to measure and control the edge of a belt? The belt is metal and could get a...
1,166
