M12 Ethernet in Class 1 Div. 2 / ATEX Zone 2
kdcui
Dec 2007
USA
386
Hi -
I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing in the way of M12 receptables (I do see plenty of RJ45).
I have concerns with RJ45 durability in a harsh environment (such as RJ45 connectors snapping). I've pretty much used M12 exclusively in cleanroom environments but not in hazardous areas.
Does anyone have experience with M12 in hazardous areas? Alternatively, does anyone have positive experience with "ruggedized" RJ45?
i looked at the Balluff brand we use and they do not list it for hazardous locations. the biggest hurdle i see is that the cable is rated for 4 amps.
what are you communicating with via the cable?
i am familiar with the rules in your situation. i was in the munitions industry for 8 years. there are a lot of unknowns right now.
james
Is the terminals in a C1D2 area or does the cable break the boundaries? Without a lot of details its impossible to help you out.
What Ethernet are you talking about? EthernetI/P , Profi, Ethercat, etc etc. I wouldn't be concerned at all about the RJ45 unless you plan on abusing them. You can see RJ45 on the side of so many industrial robots and devices. If you are putting it in harms way, you need to design the failure mode out of the installation.
We have build several protective shield because the customer was concerned.
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,509
Hi, Many analog sensors come with M12 connection and up to now for own uses and not so crutial meassurements I have used non shielded M12...
2,027
First thing, do you put labels on all your M12 cables? Second thing, do you label each wire coming out of as flying leads to be used in the...
2,747
Hi all, I am using a Kuebler encoder in our machine, it is profibus communicable and has M12 type ports. There are 3 M12 ports, 1st for profibus...
1,936
Hey Guys, Can anyone help me interface a 5 pin M12 (Pepperl and Fuchs V15-G-10M-PVC) to a DB9 male connection for serial interface between a LED...
2,667
