M12 5 pin to DB9 male
Sep 2015
Melbourne
29
Hey Guys,
Can anyone help me interface a 5 pin M12 (Pepperl and Fuchs V15-G-10M-PVC)
to a DB9 male connection for serial interface between a LED scanner and a PLC.
Thank you
Hey Guys,
Thank you
I have a piece of string, could you tell me how long it is please ?
What help do you want exactly ? Without knowing the models and pin outs of the LED scanner and PLC then people may struggle to help.......
I could be wrong, but it looks like the Pepperl and Fuchs V15-G-10M-PVC part number is only a corset with a 5-pin connector and flying leads.
You would need to supply the pin out of the device that it's connecting to in order to discern how to connect the flying leads to the DB9.
This PDF shows the colors of the leads and what pin they're connected to (the 5-pin corset only):
http://files.pepperl-fuchs.com/selector_files/navi/productInfo/edb/109479_eng.pdf
That typo is too funny ... I was about to correct it but then others would not understand your comet (comment).
If it's a Multiray scanner,
you need to connect an 8 pin cable to RS232. The 5 pin is for power.
M12-8 to DB9:
3(Rx) to 3(Tx)
4(Tx) to 2(Rx)
7(Gnd) to 5(Gnd)
For the M12-5 power cable:
Brown (1) is +24DC
Blue (3) is return
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,511
First thing, do you put labels on all your M12 cables? Second thing, do you label each wire coming out of as flying leads to be used in the...
2,747
I'm looking for an odd part... if it even exists. I need a 90 degree 'adapter' for a 5-pin M12 connector. There is currently a 'straight'...
3,555
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
983
Hi, Many analog sensors come with M12 connection and up to now for own uses and not so crutial meassurements I have used non shielded M12...
2,027
