M12 shielded connecting
rQx
Oct 2010
Trelleborg
1,051
Many analog sensors come with M12 connection and up to now for own uses and not so crutial meassurements I have used non shielded M12 cabling. Now we are in the process of selling a solution where I wan't to have panel mounted M12 connections in my control panel for the customer to connect to. Also some sensors without M12 I will add M12 connection to.
The most common patch cable I've found has the shield wired to the metall nut connecting the M12 male and female. I don't see how this can be used to a sensor since I don't want to connect the shield to ground at the sensor level.
I've also found that there is foil shielded cables that use the 5th pin as a drain wire. This is sort of what I'm thinking I wan't to use. Then I can do whatever I want with the shielding.
My other solution is going for industrial plugs, like Weidmuller Rockstar series. This may be more versatile but then I also need to make the connection coord (or patch cable) myself, going from the Rockstar outlet to a M12 connection.
Looking for some more experienced users that can guide me what is more commonly used and why?
Thankful for some inputs
/Tim
If you put unshielded plastic M12 connector on your customer side, shield will not be connected at sensor level. You can provide with your equipment two connectors, one plastic on metal, for every sensor and manual how to connect.
I can do that when the sensor doesn't have M12 built in, but for instance a pressure transmitter we use are of metall and M12 connector is also metall, so no option there. I think the best way is with the drain wire and maintain it myself. But unsure how other solve the issue
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
985
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,511
First thing, do you put labels on all your M12 cables? Second thing, do you label each wire coming out of as flying leads to be used in the...
2,748
Hi all, I am using a Kuebler encoder in our machine, it is profibus communicable and has M12 type ports. There are 3 M12 ports, 1st for profibus...
1,937
Hey Guys, Can anyone help me interface a 5 pin M12 (Pepperl and Fuchs V15-G-10M-PVC) to a DB9 male connection for serial interface between a LED...
2,669
