Automation companies
Oct 2015
Tabriz
hello everyone
I'm working for packaging machine manufacturing company.The company is enthusiastic on becoming local distributor of any automation company and meanwhile use its products on packing machines .This company is the main customer of PLCes , AC drivers , Stepper motor drivers ,stepper motors , HMI , power supply , push buttons . i was wondering if you could introduce me famous automation companies and give your suggestion on becoming local distributor of automation companies .
best regards
hello everyone
best regards
Typically machine manufacturing and automation distribution are not mixed in the same company. You're saying you want to pick up some really good lines? Get in line. Without a proven track record and substantial distribution base, no one will look at you twice unless you're in an area where there is no current distribution.
ABB has the machinery drives and automation solutions in one company. after purchasing Baldor they now even have motion, and a distribution system that is nation wide.
OP is in northwestern Iran, which makes importing of industrial automation equipment a lot more complex than it is in an open market like the USA or the EU.
hi friends, can you help me with this question, what are designations in automation industry i.e., what are the positions available in a company.
5,316
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
59
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
94
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
216
