f16bmathis
I've got a Automaton Direct EA7-T6CL+13812B141 HMI and am using C-more programming V 2.78.
I've tried using a usb cable, Ethernet crossover cable and cannot get it to show read from panel, (it does show Make New Project, and Read From Disk) when selecting read from panel under the file menu.
The manual shows three ways to connect, Ethernet normal cable with a switch or hub, a cross over cable straight in, or a USB to the square USB port on the panel. I've tried all except the switch method. I can give that a try tomorrow.
I even went and found the IP address, and changed it to match my home IP (192.168.1.XXX) and was able to see the panel by typing in that IP in explorer.
Any ideas why it won't find it in C-more?
Thanks!
Thanks!
