Automation Direct Productivity 1000/ 2000 PLC
I am looking at using this range instead of AB compact logix.
I have had a look at the software manuals and cannot find anything that indicates if this range supports some form of AOI / UDT similar to Logix 5000.
Has anybody used these controllers utilizing said functionality.
Thanks in advance.
There is no ADT/UDT at the moment. I asked the same when I was looking into them. You have to essentially make your own. If you can't live without them, though, this is a pretty great platform.
I've got 8 or 10 2000's scattered around, that have been running for a couple of years almost flawlessly. One system had some issues where the CPU would fault and stop, but that ended up being just the incoming power. A power-line filter from AD fixed that problem up. It would always come back after a power cycle, so technically we have had zero failures with the 2000's.
Each 2000 has a local C-MORE HMI, and is also tied into the site Ignition system. It all works fine using a Kepware driver for Ignition.
Anyone have experience with enabling user password security accounts on the Productivity suite? I did and now transfer is unavailable. It locked...
2,052
We have done our R&D in AD Prod 2000 we are looking at making a change in PLC either got to the DO more series or another vendor. Does anyone...
1,632
Im having a lot of trouble programming a Minutes and Seconds count down timer display in Productivity Software. Is there a math instruction that...
1,966
Hello, Has anyone ever tried to get comms working between an Advantech WebOP-2070T panel and an Automation Direct Productivity 2000 PLC? I...
1,916
This is a general question. We have a new controls project here with lots (40 +) temperature control loops, plus a handfull of interlocks. I am...
5,308
