Automation question but not PLC related
busarider29
Aug 2013
Midland, MI
399
I have a project that my boss wants me to try on a torque testing machine that we have. We use this machine to do durability testing on our clutches for the auto industry. The testing machine has a spindle with an inertia wheel attached to it. We spin up the inertia wheel and then when it reaches a pre-set RPM, we engage the clutch. We want to measure the sound of each engagement and if that sound surpasses a pre-set level, we want to stop the machine. As of right now, I'm trying out a cheap analog output sound sensor used in hobby robotics. It uses a tiny 2-wire microphone like you can find at radio shack. I would like to measure the amplification of each impact sound but not sure how I can do that, and do it CHEAP. Maybe its simple?? I have a Phoenix Contact transducer module (MCR-f-UI-DC)that I can measure the frequency of the sound, but I don't think that is what I want?? I also have an OMEGA signal conditioner (DMD-465WB)typically used for load cells. I haven't tested that yet but I'm thinking that's what I need to use? And have the output of that go to the Phoenix Contact transducer module to e-stop the machine? I just want to get some ideas out there on the best way to accomplish this. This is the sound sensor that I'm trying - (http://www.dfrobot.com/index.php?route=product/product&product_id=83#.Uq9n_Hoo6M8)
Why not just use it with an Arduino as it was designed?
This will give sound intensity. Is that what you want? Or does the sound tend to change in pitch?
Hey Bernie,
Thanks for the reply. Well, I'm not familiar with Arduino and I didn't think it was necessary as long as the sensor had an analog output, which this one does. I can read the output in Hz or mV, so my thought was that was all I needed to accomplish this task coupled with the transducer module that I have and/or the signal conditioner if reading in mV.
I am doing a wire spooling application using an Automation Direct D-260 cpu, F2-8AD4DA-2 16 bit 8 ch in / 12 bit 4 ch out 0-10 vdc board. The...
5,411
Hi, I am loking for question and answer for Automation Engineer on allen bradley PLC. This could be send to my email address at...
18
8,452
Hi all, i have an EZ Automation EZRPL-CPU-1UE and other components. I am being told that this is an Omron brand plc. I thought it was an...
1,414
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,106
hello all, I am working first time in B & r automation products. I dont know anything about B & R. I am experienced in siemens. I have one power...
4,086
