Avast and Rockwell Activations
bluenoser337
Apr 2003
Nova Scotia
391
Since last week, when I installed the paid version of Avast Antivirus I am getting activation failures on all Rockwell software. I mostly use 500 and 5000. Then, out of the blue, sometimes I get the "successful activation" message. A restart doesn't fix it, and not sure about turning off Avast. Anyone run into this and have a cure? Thanks!!
Update: Just checked in Activation Manager and the server was stopped. Restarted, it ran a few seconds...and then stopped again??!!
Perhaps you just need to add an "exception" to the Avast configuration. It looks like it doesn't recognise the activation service and is shutting it down to (supposedly) protect you...
Thanks daba!! I turned off Avast and the activation server kept running after I restarted it again. Now, I just have to figure out how to add an exclusion.
If it's not obvious, doesn't Avast have an online chat facility, I think they did a few years ago when a client had an issue, my memory is hazy, but I think they got talked through how to add an exception....
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
22
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
