CoastalControl
Hello friends,
The opportunity I am faced with is as follows.
B875-111 Wired for analog 4-20, Dip switches set correctly.
Wire a DT500-A111 (4-20) to Channel 1
Wired another DT500-A111 (4-20) to Channel 6
Both have the same power supply @ 24V.
Problem (Opportunity): When either of the DT500-A111 are connected, it functions perfectly. Set up fine and reads fine. All measurements are exact.
When both are connected at the same time, the counts change considerably and it appears as if they are at the same count they would be if it were averaging each others current input.
I would appreciate any help on this issue.
Thank you,
Pat
Thank you,
Pat
