What I am looking for exactly is how to check the status of the card through the code and shows that on the HMI. so is there any specific address I need to use or any instruction?
You could have a look at %SW180 - %sw339. they give the health status of all the modules on the rack, ive always only used for IO modules but id assume it would do the same with a NOE Card.
Yes, mbp_mstr is a function block that will send a command to the module to get information. The function code to use is 'get_local_stats' in the mstr block which will give you status information about the Ethernet module. It's in the user manual.
