Modicon Quantum PLC swap question
Strokur
Jan 2014
Ohio
62
I have a backup Processor which is identical to the processor running my plant (140 CPU 652 60).
If I load the same project into this backup controller I should be able to power down the active PLC remove the controller and replace it, everything would be identical (the memory cards as well). This would work correct?
Assuming the above works as I would want it to, how would I get the Current Init Values that haven't been replaced in the main program onto the program I wanted to put on the back up controller? once on the back up controller I could make other changes as well then build/save and then swap out.
My initial thought was I could disconnect from the active controller and it would ask to update the values. I would do that then instead of stopping the PLC and uploading it couldn't I just rebuild the project save it and upload it into the back up? I might be missing something but this would avoid costing me 2+ hrs of commuting for a very minor change (adding 3 cards to a drop and expanding the memory allocated for our %m register bits.
I appreciate any and all suggestions and help.
Thank you!
Phil
you can use unity PLC->save data from PLC to file to save the contents of the PLC memory to a file, then restore that file to the new processor using PLC->restore data from PLC to file.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
275
Hi, Any one know how I can check the status of the Ethernet card NOE77111 status or if there is any communication fault? Thank you!
2,343
Hi, I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The...
4,546
hello, we are using modicon quantum plc and its progrraming software concepr2.2, we have one repeated problem from last many days that our...
2,221
Good Afternoon everyone, I am a newbie (even though I am 50!!!) to plc programming, but have been handed an "oportunity" to program a Unity...
2,277
