back up from plc
seee
Dec 2010
singapor
112
hello.
suppose that i have a s7-300 plc with cpu315 which has a mc card and battery.there is an op17 that values of op transferred to retentive db on cpu.
will all data on mc be erased if the battery became disconnected?
what does happen on value of db and op if i download the earlier backup file to the plc?
i have a cpu with part number 315-2af01-0ab0.are data blocks in this cpu retentive?
best regards.
hello.
Not if the power (24V) is on.
You will get the old values from the backup.
If you have the gear to download, why not do an upload imediately?
The DB's values survive a restart of the CPU. Still it might be done a programmed (p)reset in the startup OBs.
Kalle
thanks a lot for your reply.
please excuse me because my english isn't good. are you mean that value of dbs will not be erased after power down of cpu?
are db values saved in mc card?
if i turn off cpu(remove 24v) and pull out the battery the data saved
in mc card will be erased or not?
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
84
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
84
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
300
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
149
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
109
