backup battery issue
dedic
Dec 2015
erbil
hi
i have some issue with battery in the electric smart meter the battery dies after 2 month they most work 5 year
you can see the pic in the attachment file below,
hi mickey,
i have new one but the problem when i replace the battery he dies after 2 or 3 month
i need to product battery from high voltage i don't know if this problem from battery or electric volt because in iraq the volt is not stable
i have more than 5000 smart meters the battery dies in the same week and i lost all data on the meters
and if resistors product battery life from high volt or high frequency.
(sorry for my english)
hi steve,
the company who make this meters say this problem from high volt or high frequency
the company who make the battery say this problem high temperature because in iraq we have 60° in the summer but i have this issue last 3 week.
i lose my money because i give 2 years of warranty on the meters and 3 years on the battery.
hi
pic NO#1 i use this 4 battery for 3 month as test battery but all battery dies after 2 month
pic NO#2 can i use resister for protract my battery from high or low volt
or frequency
thanks
I don't believe the problem is high voltage or high frequency.
A resistor won't help.
Batteries work on chemical reaction. Heat increases the chemical reactions. If heat gets high enough, you can have thermal runaway where the battery self-destructs.
I still think the problem is heat. Try storing a new battery inside the meter. Don't connect it to anything, just leave it in the package. If heat is the problem, it will kill the battery in storage.
Send bad batteries out to a lab for failure analysis.
the solution
thanks for your support
i send this test to factory who made this meters they said this is our fault
the battery most supply microchip when the electric is off but it show me the battery supply for all time
You may need to look at the electrolytic capacitors on these boards.
From what I see on your picture at least one of them is a cheaper grade rated at 85 deg C
They most likely have an excessive leakage under warm (hot) temperatures and can dry out fast also.
You should replace them with more expensive long life 105 deg C capacitors
hi contr_conn
the factory said we have manufacturers mistake so we will indemnity for you and they will repair all electricity meters
I have been tasked to supply a location with a backup power supply that can run 240V at 20 amp nominal with 70 amp peak pump loads (120 Seconds...
3,757
Good morning: Has anyone used a Li-ion 18650 for battery backup on a CLX 5550. i'm working on a trainer that will be power off for fairly long...
1,604
First to say... I'm a systems manager with wide interest in PLC's. But I'm New. We have a Symac C200He CPU42PLC in the house. Last sunday we have...
1,554
My customer has pulled the backup battery out of his Click PLC. How long should the memory last without power and backup battery, and will I lose...
3,040
I have a PanelView Component 2711C-K3M Connected to a Micrologix1400. If I shut down power to the machine, the Micrologix goes dead, my 24V...
1,755
