basic beginer, needing help
buckshot
Feb 2007
house
Is or isn't this the right place to ask questions and recieve answers? I will ask again my question
I have just received a Mecman IPC 500J with, -- 3 modules having 8 inputs each and 2 modules having 8 outputs each and 1 dummy module.
It is a 1K E2 PROM memory chip and typed on it is;
Line: 6720 KRYMPPL.
File: 6720
MECMAN 950515
I would like to use this IPC (PLC) on a hobby machine that I am building. I understand a small amount about PLC’s, but what I don’t know is what software to use for MECMAN type plc. Is there someone out there that can help me? Thanks
As Steve said
Steve Bailey said:
This is a great place to ask questions. Sometimes you get immediate answers, sometimes you don't.
I did a search for mecman on this site and found these threads
http://www.plctalk.net/qanda/showthread.php?t=1356&highlight=Mecman
http://www.plctalk.net/qanda/showthread.php?t=9855&highlight=Mecman
And of course your threads. Judging by the responses from these there isn't much available and this appears to be a very old and outdated PLC. You might try to follow some of the suggestions from these previous threads.
I did find this page on mecman at plccenter
http://www.plccenter.com/ManListpage.aspx?Manufacturer=Mecman&ManufacturerConj=And&PartNo=&PartNoConj=And&Desc=&Specials=false&InStock=false&TopCategory=&Category=
The valves listed are rexroth items that Steve might have been refering to.
Good luck
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
227
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
422
1,992
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,089
Hey Programmers, Heres todays puzzle I was trying to solve... I have a Modbus TCP network with two Modicon M221 controllers live on my work bench...
481
