Basic Question about analog input
hanachen
Nov 2009
Atlanta
Hi,I am new to PLC and I want to do some simple task.
Now I have a DC power and a pot. I want to connect these two to my PLC's analog input module and display the voltage when I adjust the pot. Could you give me some advice? Thanks
Put pot maximum (full CW) to +DC of power supply, put minimum ( Full CCW) to dc ground, dc ground should also be connected to analog board ground, use potentiometer wiper as analog signal and connect it to your analog input, you did not mention your power supply voltage, let´s assume it is 10 VDC, so configure your analog inpou as 0-10 VDC, then you can scale this value to whatever you need it.
You'll need to know the type of analog input (0-10V, -10V to 10V, 4-20mA)
And you'll need to know the DC voltage of your power supply. You probably don't want to hook 24V to your 10V analog input (I don't know if it will hurt it or not, but why bother?)
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
239
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,293
Dear experts, i have pretty basic/ dump question, can someone help me to figure out how to read/ what is this? i assume it is solenoid vavle...
1,078
Create ladder logic program to count 4 on pulses (not using a counter) and then turn the output on if the on pulse input signal can look like the...
105
36,853
Im looking to hook up a 3 wire PNP photocell to an Allen Bradley 1746IV 16 module. Ive watched videos about hooking up DC sensors, but they show...
3,042
