sanoflex Member S Join Date Feb 2022 Location Germany Posts 3 Feb 18, 2022 #1 Dear experts, i have pretty basic/ dump question, can someone help me to figure out how to read/ what is this? i assume it is solenoid vavle, do i have right?
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,324 Feb 18, 2022 #2 I think it is the two coils on a 5/3-way solenoid valve. And it is integrated into a valve block with a fieldbus interface, hence the outputs Q289.0 and Q289.1.
sparky66 Member S Join Date Jan 2012 Location Ohio Posts 82 Feb 18, 2022 #3 That is a gate valve symbol. I would expect it to be motorized, but it is missing the "M" in the block.
parky Member P Join Date Oct 2004 Location Midlands Posts 5,748 Feb 18, 2022 #4 MPA-2 refers to the 20mm block type so I suspect it is a 5/3 valve as it's size is small & no motor would fit into it.
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,324 Feb 18, 2022 #5 If it is motorized the symbols should be different.
