Batch Plant help
jcurado
Sep 2003
49
I will do a batch plant and can really use some advice.
There will be 4 weighing systems feed thru 9 different silos. I don’t expect problems with that.
It will also need 2 “self-weighing belts”, where the product should be weigh when passing over. Here I cannot batch de product. I need to know the amount of product that outputs from the belt so I can stop the belt when set point is reached (OK, I know that the accuracy of that is not perfect, but that is not a problem in this case).
I used to do this with a PENKO flux controller, communicating with the PLC. This time I would like to use a Telemecanique TSX Premium.
I know there Telemecanique as weigh controllers for Premuim PLC. Do you know if we can to this with that controller? Have any of you already done it.
Thank you
João
Has anyone ever used the S88 batch standard in aWastewater treatment plant? References?
2,810
Hi Everyone, Thought I had it figured out but I came to the conclusion it would not work. Here is what I'm working with... 1769-L30ER Flow Meter...
24
731
Does anyone have expereince creating a custom API to build a campaign management system for FactoryTalk Batch? Stuck between using a REST API or...
485
https://literature.rockwellautomation.com/idc/groups/literature/documents/qs/iasimp-qs042_-en-p.pdf The video links in this pdf are not working...
1,140
Can someone shed some light on what the connector is that allows Batch to connect to Historian and create historical trends based on batch...
704
