battery monitoring
bergis
Mar 2017
Borås
Hello
I want to make a 24V battery monitoring. I'll raise the alarm before the batteries are completely empty. there are two 12- volt batteries and I'll check the current on them once a week.
while I will measure and I'll turn off the charger and put on a load of batteries to measure the discharge.
I've got a Schnider sr2 b121bd
how do I do this ??? please help:cry:
Hello
You need to check the voltage if you want to check battery health, you could use any voltage/current sensor or use a dedicated battery monitor:
http://www.clrwtr.com/Weidmuller-Monitoring-Modules.htm
http://www.argacontrols.com/battery.htm
Generally pay $1500 AU for my battery chargers - pretty flash though - huge - mounted on a plate. Even detect the battery centre point for uneven battery voltage/failure.
Yep, the PULS ones have that function too, we use them for sets up to 100Ah without issues.
I don't really get this reinventing the wheel attitude when you can buy off the shelf components that will give you everything you need for a couple of hundred £
And the flaw in the OP's method is turning the charger off to monitor the battery, what if the battery is indeed kaput and your charger is holding the load up ?
I need to send out an alarm signal when the batteries lose power
and I need to turn off the battery charger when I measure the battery
I need to do this test once a week
But if you turn off the battery charger to measure the battery and the battery has failed since the last time you tested it you will loose your supply. :confused: :unsure:
What model of charger are you using ?
The monitoring device and chargers i linked to can do all this for you.
Mostly here we have battery chargers specified by electrical consultants. They invariably specify up to 20 digital outputs for monitoring by a PLC or BMS system. They have to be built to suit the specification. Common alarm is not enough for most of my jobs.
Turning chargers off for an hour is also quite common here to test the batteries. Measure the battery voltage across all batteries at the start and at the end. Also normally specified. Helps pick up failing cells.
Different requirements in different companies and parts of the world?
Is it Possible to Monitor PLC CPU Battery Voltage Level through Special Register in Mitsubishi QCPU other than when the Battery is Already Low????
1,249
Hi, I'm looking to add cell stack voltage monitoring functionality to the PLC system (attached picture). I have several analog modules (TM2AMI2HT)...
1,846
hi guys, I want to display state of the battery charger into the HMI through a PLC. I want the status of "charge,off,fail" of the battery charger...
4,095
Im wonderring if the is a system variable or its possible in an other way to get information in to the PLC code about the backup battery on the...
3,918
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
259
